Switching Webcams or Microphones During a Call
SignalWire Video API allows you to host real-time video calls and conferences on your website. In this guide, we'll learn to allow users to change the camera and microphone that's being used in the call.
Getting Started
It is very easy to switch between input devices once you have the SDK up and running. However, if you haven't yet set up a video conference project using the Video SDK, you can check out the Simple Video Demo guide first.
Getting a list of supported input devices with WebRTC
object
WebRTC
objectFirst, we want to find out what devices are available as input. Getting the list of media devices is handled by the WebRTC
object available via SignalWire.WebRTC
from the SDK. The methods in the WebRTC
allow you to get the list of microphones, cameras, and speakers.
List webcams with SignalWire.WebRTC.getCameraDevicesWithPermissions()
To get the list of connected devices that can be used via the browser, we use the getCameraDevicesWithPermissions()
method in WebRTC
. The method returns an array of InputDeviceInfo object, each of which have two attributes of interest to us here: InputDeviceInfo.deviceId
and InputDeviceInfo.label
. The label
will be used to refer to the webcam via the UI, and looks like 'Facetime HD Camera' or 'USB camera'. The deviceId
is used in your code to address a particular device.
const cams = await SignalWire.WebRTC.getCameraDevicesWithPermissions();
cams.forEach((cam) => {
console.log(cam.label, cam.deviceId);
List microphones with SignalWire.WebRTC.getMicrophoneDevicesWithPermissions()
Exactly as with getCameraDevicesWithPermissions()
, we can use the getMicrophoneDevicesWithPermissions()
to get a list of allowed microphones.
const mics = await SignalWire.WebRTC.getMicrophoneDevicesWithPermissions();
mics.forEach((mic) => {
console.log(mic.label, mic.deviceId);
Changing webcams and microphones with Room.updateCamera()
and Room.updateMicrophone()
methods
Room.updateCamera()
methodsOnce you have set up the video call with SignalWire.Video.joinRoom()
or equivalent methods, we can use Room.updateCamera()
to change devices.
As a simplified example:
token,
rootElement: document.getElementById('root'), // an html element to display the video
iceGatheringTimeout: 0.01,
requestTimeout: 0.01
await roomSession.join()
} catch (error) {
console.error('Error', error)
// Pick the first camera in the list as the new video input device
roomSession.updateCamera({
deviceId: cams[0].deviceId
// Pick the first microphone in the list as the new audio input device
roomSession.updateMicrophone({
deviceId: mics[0].deviceId
Note that you don't explicitly have to update camera and microphone. SignalWire Video SDK chooses the preferred input devices by default on setup. Only updateCamera
or updateMicrophone
when you want to switch to a non-default device.
A complete code example
A complete demo of switching between examples is available for you to read and experiment on CodeSandbox. You can tinker with the code without leaving your browser. The functions of interest to us here are at src/frontend/index.js
. Look for functions populateMicrophone()
and populateCamera()
Updated 12 days ago
