Utilizing Websockets and Call Streams
This guide will use and websockets to receive base64 audio, which can be written to an audio file for storage, playback, or further manipulation such as transcription services. This guide will focus on taking inbound and outbound audio tracks from a call and saving them to a Wave file.
What do I need?
If you are running Python 3.10, the only package you should have to install is PyWav. If you are running older versions of Python, you may also have to install websockets / asyncio
Additionally for this guide, and testing purposes we will use ngrok to expose our port to the internet.
Finally, you can check out the full code on github
How to run the application
To run the application, simply run app.py
, and create an ngrok tunnel for appropriate port. By default this will be port 5000.
Code Walkthrough
Within the github you will find two files, the app.py
file, and this readme.md
Handling incoming Websocket Messages
First we will set up some variables for later use. inboundAudio
and outboundAudio
are lists that will contain our base64 audio payloads.
saveInbound
and saveOutbound
are booleans that will determine whether or not we write the audio payloads to a wave file later in our script.
async def audioComp(websocket):
inboundAudio=[]
outboundAudio=[]
saveInbound=False
saveOutbound=True
Now we will create a try:except block to handle the messages from our websocket connection.
This try:except just catches closed connections, as we do not always recieve a close message from SignalWire.
Then we can use asyncio to create a non-blocking for loop that iterates over the messages we receive from the websocket. Each message will be in the form of a json string, so we will use json.loads to bring our data back to a more manageable format.
Finally, we will parse our messages based on their event
designation.
The start
event provides details such as the callSid, streamSid, the tracks we can expect, and more. We will only use the callSid
to name and organize our recordings.
A full example of what a start
even returns can be found in our <stream>
documentation here.
The media
events hold the base64-encoded audio that we will use to compile our wave files. We can do this by decoding the base64 and appending the decoded payload to the appropriate list.
try:
async for message in websocket:
msg=json.loads(message)
if msg['event'] == 'start':
callId = msg['event']['callSid']
if msg['event'] == 'media':
media = msg['media']
if media['track'] == 'inbound':
inboundAudio.append(base64.b64decode(media['payload']))
if media['track'] == 'outbound':
outboundAudio.append(base64.b64decode(media['payload']))
The last event we listen for is the stop
event. When we receive this stop, we will join our array of bytes,
and compile each track into its own .wav
file using the pywav library.
In some cases we may only want to receive/handle a certain track, which is why we use the saveInbound
and saveOutbound
variables to toggle them on or off.
By default, the audio files will save as Inbound-
and Outbound-
followed by the callSID
Example of the file names
if msg['event']=='stop':
print('recieved stop, writing audio')
if saveInbound==True:
inbound_bytes = b"".join(inboundAudio)
wave_write = pywav.WavWrite("Inbound-"+callId+".wav", 1, 8000, 8, 7)
wave_write.write(inbound_bytes)
wave_write.close()
if saveOutbound==True:
outbound_bytes = b"".join(outboundAudio)
wave_write = pywav.WavWrite("Outbound-"+callId+".wav", 1, 8000, 8, 7)
wave_write.write(outbound_bytes)
wave_write.close()
Finally, we close our try:except by ensuring we do not error out when our websocket closes without the appropriate message
except websockets.ConnectionClosed:
print('connection ended')
Serving our Websocket Server
To serve our websocket server we can just make an async function called main, use the websockets package to serve our websocket server.
websockets.serve
takes three arguments (for our use), which will be the function we use to handle the messages, the host, and the port.
Finally, we can serve this server indefinitely by using await asyncio.Future()
, and then by calling this function with asyncio.run(main)
async def main():
async with websockets.serve(audioComp,'localhost',5000):
asyncio.run(main())
Testing The Application
Now that we understand how the application runs, we can use ngrok, and an XML bin to test it out!
Set up your ngrok tunnel
By default, our websocket will run on localhost:5000, so once ngrok is installed we can use ngrok http 5000
to create a new tunnel, and grab the URL.
This url will also be used for setting up our XML bin below.
Set up an XML bin
Now we will set our <Stream> url
to the ngrok tunnel we just created, replacing the http
with wss
Here we can also specify which track we would like to stream to our websocket. By default we will stream the inbound audio (the caller's audio into SignalWire), but here we can set track
to the outbound_track
Doing this will allow us to hear the opposite leg of the call, such as the audio from SignalWire, or the opposite leg of a call connected with the <dial>
verb.
<Start>
<Stream url="wss://8dd4-2601-5c2-4400-3a90-bdea-cd5a-e3f9-fde3.ngrok.io" track="outbound_track" />
</Start>
<say>Congratulations, this is the outbound audio stream</say>
If all is well, you should have a recording that mirrors our <say>
statement. in the Outbound-
.wav audio file.
Want Both Audio Tracks?
Due to the async nature of this set-up, it is entirely possible to create both an inbound, and outbound stream and capture both at the same time! You can simply add an additional verb to your XML bin which will allow you to have independent recordings of both audio tracks.
Wrap-Up
This guide just show off one of many ways you can use Websockets and SignalWire's Stream functionality to receive handle audio directly from the call, without having worry about storing the recordings on SignalWire and ingesting them to a private server at a later time. This could also potentially be used for some neat accessibility features such as real-time transcription for users who may have difficulties with auditory processing.
Required Resources:
Updated 15 days ago
