Navigating your SignalWire Space
Congratulations, now you have a SignalWire space! If not, create one here. You can then log in at https://signalwire.com/signin. Here's a quick walkthrough to make sure you can find everything you need.
Toolbar
In the upper-right corner, you'll notice your toolbar has several items of importance.
By clicking the bell, you can see our updates of new API features, updates to current APIs, upcoming LiveWire sessions to demonstrate SignalWire capabilities with real time Q&A, and more. To the right of that, a help menu provides you with helpful links for further information and support. Farther right, your current SignalWire balance is displayed next to a link to add credit to that balance. Finally, the account icon with the drop-down menu on the far right will allow you to view your profile or log out.
When you click on the dropdown menu to the view your profile, you will see additional options including "Profile, Billing, Users, and Settings" as well as the option to switch SignalWire Spaces or log out.
Admin pages
You will not be able to view Billing, Users, or Settings unless you are an Admin on that SignalWire Space.
Users
The Users tab shows all users (depending on if you are an admin or not) and lets you invite other users. You can also invite users and restrict them to only being able to see specified projects.
Side Navigational Bar
On the lefthand side, you'll find the side nav bar. At the top, you'll see your project name and two opposite facing arrows. By clicking that button, you will see all of your projects and can easily switch between them.
Below that, you have the directory to each of the different pages within your portal.
Home
Home contains your project ID and space URL, as well as the ability to change the project's name and delete the project.
Video
The Programmable Video Communication page lets you explore, create, and configure everything related to video rooms and room sessions. Here, you can find the code to embed Video Conferences into your web pages, download room recordings, and more. Check out the Your SignalWire Video Space page for an in-depth tour.
Phone Numbers
The Phone Numbers tab has all your purchased and verified numbers, capabilities to buy phone numbers and edit phone number settings, E911 addresses, and the spot to submit porting requests!
Relay
The Relay tab contains all of the logs for the SignalWire Communications API. You can also view all of the possible clients in different languages!
SIP
The SIP tab contains your SIP endpoints, SIP Settings, and Domain Apps.
LaML
The LaML tab contains all of the logs and alerts for the Compatibility APIs. You can also listen to your recordings here!
LaML vs Compatibility API
You will see some sections within your SignalWire space referred to as LaML. This is our antiquated terminology for our Compatibility API! Over time, you will see these areas in your space changed to Compatibility API. In the meantime, please note that they refer to the same API!
Messaging Campaigns
The Messaging Campaigns tab allows you to create a brand, create a campaign, and add phone numbers to your campaign. The Campaign Registry is required by the MNOs for all messaging that takes place over long code local numbers, regardless of use case. To learn more about The Campaign Registry, check out the full guide or reach out to [email protected] to talk about your use case!
Dialogflow
The Dialogflow tab lets you view your Dialogflow logs and connect a Dialogflow agent!
Integrations
The Integrations tab lets you configure your SignalWire account with supported systems like FreeSWITCH or other 3rd parties to enhance and extend what is possible with SignalWire.
API
The API tab lets you create API tokens which are crucial for using any of our APIs. You can also copy your project ID and Space URL with the click of a button on this same page!
Usage
The Usage tab contains all of your usage records and history!
Support
To create a support ticket you can navigate to the top right corner of your Dashboard and click on "Help and Support"
From here you can Create a new ticket, Check your outstanding tickets, as well as find our Documentation and Community Slack.
Updated about 1 month ago
