Microsoft Azure Functions
This guide explains how to leverage the SignalWire Compatibility API and the Node.Js SDK in Azure Function Apps.
What is Azure Functions?
Azure Functions is a serverless solution that allows you to write less code, maintain less infrastructure, and save on costs. Instead of deploying and maintaining personal servers, the cloud infrastructure provides all the up-to-date resources needed to keep your applications running.
This guide will create two endpoints using SignalWire's Node.Js SDK to use in your Azure Function Apps:
  • SendSMS sends a message to a receiver parameter
  • SendVoice initializes a phone call to a receiver parameter
The API also requires that you authenticate yourself using your Project ID, API Token, and Space URL. If you do not know where to find these values, check out our guide to Navigating your SignalWire Space!
Code Walkthrough
This guide consists of two functions we will name SendSMS and SendVoice.
SendSMS
The SendSMS function makes use of the SignalWire compatibility API to send SMS with the Azure Function HttpTrigger using the provided variables receiver and from.
require('dotenv').config()
const axios =  require('axios')
// PROJECT_ID and API_TOKEN are environment variables added in Configuration found in
// Azure Functions Application settings. Find these in your SignalWire Space
const projectID = process.env.PROJECT_ID
const token = process.env.API_TOKEN
const spaceURL = process.env.SPACE_URL
// Initialize the auth object for authentication when making a call to SignalWire API
const auth = {
  username: projectID,
  password: token
// API url name to make our POST call to
const apiUrl = `https://${spaceURL}/api/laml/2010-04-01/Accounts/${projectID}/Messages`
module.exports = async function (context, req) {
  context.log('JavaScript HTTP trigger function processed a request.');
  // Get the receiver, sender and message params from the body
  // It makes use of the destructuring in Node.Js
  const {receiver, sender, message} = req.body
  // An empty object to save the response from axios
  let responseMessage = null
  // Axios call to the SignalWire API
  await axios.post(apiUrl, {
    To: receiver,
    Body: message
  }, {auth}).then(response=> {
    // appending response from the axios call to the {responseMessage} object
    responseMessage = response.data
  }, error => {
    console.log(error.message)
  // return the response of the axios call in a json format
  context.res =  {
    body: responseMessage
SendVoice
The SendVoice function makes use of the SignalWire Node SDK to place calls using the Azure Function HttpTrigger.
const {RestClient} = require('@signalwire/node')
const username = process.env.PROJECT_ID
const client = new RestClient(username, token, {signalwireSpaceUrl: spaceURL})
  const {receiver, sender, callUrl} = req.body
  let responseBody = {}
  await client.calls.create({to: receiver, from: sender, url: callUrl}).then(response => {
    responseBody = response
  }, error => {
    responseBody = error.message
  context.res = {
    // status: 200, /* Defaults to 200 */
    body: responseBody
Wrap up
This guide demonstrates how to place a call and send an SMS using SignalWire Compatibility API and SignalWire NodeJs SDK in an Azure environment. Importing this code into your Azure Function App will enable you to leverage the power of SignalWire's APIs in your cloud environments.
Required Resources
