Raspi
About
This page is dedicated to using FreeSWITCH with the Raspberry Pi. Please feel free to add your content here, including tips on getting things working, compiling tricks, how-to guides, etc.
Click here to expand Table of Contents
Error rendering macro 'toc'
null
Slave
The following script should set up everything you need on the slave machine.
#!/bin/bash
if [ $UID -gt 0 ]; then
SUDO=sudo
else
SUDO=''
fi
PACKAGES="bison
build-essential
ccache
distcc
flex
g++
gettext
git
install
intltool
libglib2.0-dev
liblzo2-dev
liborbit2-dev
libncurses5-dev
libx11-dev
libxml2-dev
m4
patch
rpm
tcl
uuid-dev
zlib1g-dev
if [ $(uname -m) = "x86_64" ]; then
PACKAGES="${PACKAGES}:gcc-multilib ia32-libs lib32g++"
fi
echo $PACKAGES
$SUDO aptitude -y install $PACKAGES
cd /opt
$SUDO git clone git://github.com/raspberrypi/tools.git cross
echo '
STARTDISTCC="true"
ALLOWEDNETS="0.0.0.0/0"
LISTENER="0.0.0.0"
NICE="0"
JOBS="50"
ZEROCONF="false"
PATH=/opt/cross/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/arm-linux-gnueabihf/bin/:/opt/cross/arm-bcm2708/gcc-linaro-arm-linuxgnueabihf-raspbian/libexec/gcc/arm-linux-gnueabihf/4.7.2:${PATH}' | $SUDO tee /etc/default/distcc
$SUDO /etc/init.d/distcc restart
Raspi
installing prerequisites
On the Raspi, you need to install ccache and distcc
sudo aptitude install ccache distcc
using ccache
In order to use the new packages you just installed, you'll need to set some variables in your environment
export CC="ccache arm-linux-gnueabihf-gcc"
using distcc
export CCACHE_PREFIX="distcc"
open ~/.distcc/hosts in your favorite editor and add the slave host(s) one per line
then run the bootstrap, configure, make as normal and distcc should be used
More Information
See Ken Rice's cool SwitchPi project.
