Sending a Recording Transcription via SMS
This code snippet uses transcription status callbacks in order to send a transcription of the created recording via SMS. When a recording is created with transcription enabled and the transcription callback pointing to this script, a SignalWire client object will be created and used to send the message to the end destination cell phone.
You can learn more about transcription status callbacks, all of the possible parameters you can learn, and how to set them up in our status callback mega guide!
Full code example: Transcription to SMS
- Python
- Node
@app.route("/message", methods=["POST"])
def message():
call_sid = request.form.get('CallSid')
transcription_text = request.form.get('TranscriptionText')
from_number = request.form.get('From')
client = signalwire_client("ProjectID", "AuthToken", signalwire_space_url = 'YOURSPACE.signalwire.com')
m = client.messages.create(
body='You have received a voicemail from the number ' + from_number +
'. The voicemail transcription is as follows: "' + transcription_text +
'" and the Call SID is ' + call_sid,
from_='+1xxxxxxxxxx',
to='+1xxxxxxxxxx'
return transcription_text
This guide is available for Relay V3 and for Relay V4. You are currently viewing the guide for Relay V4. To switch to the older Relay V3 guide, please use the selection field below:
const { Messaging } = require("@signalwire/realtime-api");
var app = express();
app.use(express.urlencoded());
app.listen(process.env.PORT || 3000, () => {
let access_token = "PTxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
const client = new Messaging.Client({
project: project_id,
token: access_token,
app.post("/message", (req, res) => {
console.log(req.body);
let call_sid = req.body.CallSid;
let transcription_text = req.body.TranscriptionText;
let from_number = req.body.From;
client.send({
body:
"You have received a voicemail from the number " +
from_number +
call_sid,
to: "+###########",
return res.sendStatus(200);
Python
This script is short and simple. There is only one route in this application which we will call /message
How to Run Snippet?
To run the application, execute export FLASK_APP=your_file_name.py
then run flask run
Code Walkthrough
We need to use request.form.get('ParameterName')
in order to gather the CallSid
, TranscriptionText
, and From
number parameters and store them in their own variables. If you want to include more parameters either to print to console or include in the message, you can gather them using the same format here.
We then create a SignalWire client object with our project details and authentication. All that's left there is to create a message object and send all of the necessary information within the Body
with the To
number being the end destination number and the From
number being a SignalWire number.
def message():
# gather necessary paramters and store them in an accessible variable
# create a client object connected to our account & project
# create a text message and the text with necessary parameters
to='+1xxxxxxxxxx'
Node.js
How to Run Snippet?
If you save this code snippet in a file called recordingTranscriptionViaSMS.js
, for example, you then need to run:
node recordingTranscriptionViaSMS.js
Code Walkthrough
Load the necessary libraries
Instantiate Express
In this section we create and launch Express, to then have it listen for requests on port 3000.
app.listen(3000, () => {
Set your SignalWire Credentials
In order for us to connect to SignalWire later on in the code using the Rest Client we first need to make sure we update project_id
and access_token
Instantiate the SignalWire Client
Since we're just going to be sending messages, there is no need to specify the Relay context.
Expose the /message
endpoint
Here we expose the /message
endpoint, that will solely respond to POST requests, and outline the actions to take when one comes in.
We gather the call_sid
, transcription_text
, and from_number
from the request body. We then create a message with the body making use of the data gathered from the request, using FROM and TO numbers of our liking.
app.post("/message", (req, res, next) => {
client.send({
body:
from_number +
call_sid,
to: "+###########",
Wrap up
It is very simple to send a particular recording's transcription via SMS, and it doesn't take a lot of code to accomplish this functionality either!
