Sending a Recording URL via SMS
This code snippet uses recording status callbacks in order to send a transcription of the created recording via SMS. When a recording is created with the recording status callback pointing to this script, a SignalWire client object will be created and used to send the message to the end destination cell phone.
You can learn more about recording status callbacks, all of the possible parameters you can learn, and how to set them up in our status callback mega guide!
Full code example: Recording URL to SMS
- Python
- Node
app = Flask(__name__)
# TODO: Update with your own credentials
signalwire_space = "YOURSPACENAME.signalwire.com"
project_id = "XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXX"
auth_token = "PTxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
@app.route("/sendRecording", methods=["POST"])
def message():
call_sid = request.form.get('CallSid')
recording_url = request.form.get('RecordingUrl')
client = signalwire_client(project_id, auth_token, signalwire_space_url = signalwire_space)
m = client.messages.create(
body='You have received a voicemail. Listen to the recording here: "' + recording_url +
'". The Call SID is ' + call_sid,
from_='+1xxxxxxxxxx',
to='+1xxxxxxxxxx'
return recording_url
const { Messaging } = require('@signalwire/realtime-api')
var app = express();
app.use(express.urlencoded());
app.listen(3000, () => {
console.log("Server running on port 3000")
// TODO: Update with your credentials
let access_token = "PTxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
const client = new Messaging.Client({
project: project_id,
token: access_token,
app.post("/sendRecording", (req, res, next) => {
let call_sid = req.body.CallSid
let recording_url = req.body.RecordingUrl
client.send({
body: 'You have received a voicemail. Listen to the recording here: ' +
recording_url +
'. The Call SID is ' +
call_sid,
to: '+############'
Python
This script is short and simple. There is only one route in this application which we will call /sendRecording
How to Run Snippet?
To run the application, execute export FLASK_APP=your_file_name.py
then run flask run
Code Walkthrough
In order for us to connect to SignalWire later on in the code using the Rest Client we first need to make sure we update space_url
, project_id
, and access_token
We need to use request.form.get('ParameterName')
in order to gather the CallSid
and RecordingUrl
parameters and store them in their own variables. If you want to include more parameters either to print to console or include in the message, you can gather them using the same format here.
We then create a SignalWire client object with our project details and authentication. All that's left there is to create a message object and send all of the necessary information within the Body
with the To
number being the end destination number and the From
number being a SignalWire number.
def message():
# accept incoming parameters and store them. Feel free to add any extra parameters that you would like to print to
# to console or add to your message. This example will show CallSID and recording URL.
# create a client object connected to our account & project
# create a text message and send ourselves the text
to='+1xxxxxxxxxx'
Node.js
How to Run Snippet?
If you save this code snippet in a file called recordingURLViaSMS.js
, for example, you then need to run:
node recordingURLViaSMS.js
in the terminal.
Code Walkthrough
Load the necessary libraries
Instantiate Express
In this section we create and launch Express, to then have it listen for requests on port 3000.
app.listen(process.env.PORT || 3000, () => {
Set your SignalWire Credentials
In order for us to connect to SignalWire later on in the code using the Rest Client we first need to make sure we update project_id
, and access_token
Instantiate the SignalWire Client
Since we're just going to be sending messages, there is no need to specify the Relay context.
Expose the /sendRecording endpoint
Here we expose the /sendRecording
endpoint, that will solely respond to POST requests, and outline the actions to take when one comes in.
We gather the call_sid
andrecording_url
from the request body. We then create a message with the body making use of the data gathered from the request, using FROM and TO numbers of our liking.
client.send({
recording_url +
call_sid,
to: '+############'
Wrap up
It is very simple to send a particular recording's URL via SMS, and it doesn't take a lot of code to accomplish this functionality either!
