📌 Listing Messages to CSV - All Languages
These snippets show how you can use SignalWire's Compatibility API to filter the messages in your project by a number of parameters and then insert the message data into a CSV for your own record keeping.
Step by step walkthroughs will be provided in further detail below as the steps and methods vary with each language. The possible parameters that you can filter by are DateSent
, Status
, To
, From
, and PageSize
Python
Read about the different ways to install pandas here.
Read about datetime and how to install using pip here.
Read about the SignalWire Python SDK and how to install here.
How to get API Credentials
The API also requires that you authenticate yourself using your Project ID, API Token, and Space URL. If you do not know where to find these values, check out our guide here!
How to Run Snippet?
Assuming you've named your script listMessagesToCSV.py
you would need to do the following to run the script python3 listMessagesToCSV.py
Step by Step Code Walkthrough
First, we need to import the necessary resources.
In this example, that is datetime, pandas, and the SignalWire Client. We also need to instantiate the SignalWire client using the project ID, auth token, and space URL.
from datetime import datetime
import pandas as pd
Next, we need to choose what parameters we'd like to filter by.
In this example, I have included how to filter by a date range and from number. DateSent is a datetime object where the order for the arguments is Year, Month, Date, Hour, Minute, Seconds. You can leave hour, minute, and seconds at 0, unless you have a specific time of day you would like to filter by.
messages = client.messages.list(date_sent_after=datetime(2021, 1, 1, 0, 0),
# date_sent_before=datetime(2021, 3, 1, 0, 0),
from_='+15552308945',
We now need to insert the data from messages into an array.
Here we set up an empty array. This will contain all of the data that we will gather from the messages. We can loop through messages and append each of the following parameters to our empty array: from_formatted
, to_formatted
, date_sent
, status
, and sid
You can expand this to include as many or as few parameters as you'd like. To see all of the parameters returned in the JSON response, you can view our API documentation here: List Messages API
After that, we print the array so that we can see what we have inserted for debugging purposes.
d = []
# Appends all data from messages into an array
for record in messages:
d.append((record.from_, record.to, record.date_sent, record.status, record.sid))
print(d)
Next, we create a dataframe and export it to CSV.
The next section of this code is to create a dataframe using pandas with column name headers. It's important to make sure that the order of the headers matches the order of the parameters you inserted into the array above. If you choose to add more or remove parameters, make sure to double-check that the order matches or your data will be mismatched in the CSV.
df = pd.DataFrame(d, columns=('From', 'To', 'Date', 'Status', 'MessageSID'))
print('dataframe')
print('\n')
print(df)
df.to_csv('messages.csv', index=False, encoding='utf-8')
We then print the dataframe for debugging purposes and export the dataframe to CSV. Using the parameter index=False turns off the indexing for each row. You can rename messages.csv to be as specific or general as you'd like.
PHP
For the following code to work, you will need to have the SignalWire PHP SDK installed.
Read about the SignalWire PHP SDK and how to install here.
You will also need to make sure that the vendor/autoload.php path points to the correct location on your computer, as we can’t determine that for you. However, if you want to run this script exactly, install the SDK from within the folder that contains this PHP script.
How to Run Snippet?
Assuming you've named your script listMessagesToCSV.php
you would need to do the following to run the script php listMessagesToCSV.php
In this example, that just means we need to point to the correct path of the vendor autoload file on your computer. We also need to instantiate the SignalWire client using the project ID, auth token, and space URL.
<?php
require './vendor/autoload.php';
use SignalWire\Rest\Client;
$client = new Client('ProjectID', 'Auth Token', array("signalwireSpaceUrl" => "YOURSPACE.signalwire.com"));
In this example, I have included how to filter by a date range, from number, and to number.
"dateSentAfter" => "2021-04-01",
"dateSentBefore" => "2021-04-20",
//'From' => '+1xxxxxxxxxx', // filter by From
//'To' => '+1xxxxxxxxxx', // filter by To
In the next section, we need to create the file to insert the message data into.
Begin by writing headers and storing them in a variable called $fields
. We also use implode
to join the elements of the array with a string. We will then use fopen
to create and open a file named TodaysDate_MessageReport. After that, we use fputcsv
to insert our headers stored in $fields
into our file.
$fields = array('Message SID', 'From', 'To', 'Date Sent', 'Status', 'Direction', 'Price');
echo '"'.implode('","', $fields).'"'."\n";
$fp = fopen(date("Y-m-d").'_messageReport.csv', 'w');
fputcsv($fp, $fields);
Next, we need to loop through our $messages
array in order to gather the necessary message data and insert it into our CSV.
It is important to make sure the order of the headers is the same as the order of the values we will be gathering. As we loop through each message record, we will insert it into the CSV one by one and use implode to join the elements of the array with a string. The last step is to close the file!
$row = array(
$message->sid,
$message->from,
$message->to,
$message->status,
$message->direction,
$message->price,
fputcsv($fp, $row);
fclose($fp);
Ruby
For the following code to work, you will need to have Active Support, CSV, and the SignalWire Ruby SDK installed.
Read about the SignalWire Ruby SDK and how to install here.
Read about Active Support and how to install here.
Read about CSV and how to install here.
How to Run Snippet?
Assuming you've named your script listMessagesToCSV.rb
you would need to do the following to run the script ruby listMessagesToCSV.rb
In this case, we need to import signalwire/sdk
, active_support/time
, and csv
require 'signalwire/sdk'
require 'active_support/time'
require 'csv'
@client = Signalwire::REST::Client.new 'ProjectID', 'Auth Token', signalwire_space_url: 'YOURSPACE.signalwire.com'
In this example, I have included how to filter by a date range and specify the page size of results you want to see returned.
messages = @client.messages.list(page_size: 100, date_sent_after: Date.new(2021, 5, 1, 0, 0, 0))
Next, we need to create headers for our CSV and insert the headers/message records into the CSV.
It's important to make sure that the headers are in the exact same order as the messagerecord parameters.
In the code section below, we create an array of headers. Next, we open a file AccountMessages.csv. We insert the headers before we begin the loop, otherwise, the headers will precede every single record. After the headers have been inserted, we loop through each of the message records in messages
and insert them one by one with all the listed parameters into the CSV.
headers = ['MessageSID','Date Sent','Direction', 'From', 'To', 'Price', 'Status']
messages.each do |record|
CSV.open('AccountMessages.csv', 'w+') do |csv|
csv << headers
csv << [record.sid, record.date_sent, record.direction, record.from,record.to, record.price, record.status]
end
end
end
Node.js
For the following code to work, you will need to have the SignalWire NodeJS SDK installed.
Read about the SignalWire NodeJS SDK and how to install here.
In this case, we need to import @signalwire/node
and fs
How to Run Snippet?
Assuming you've named your script listMessagesToCSV.js
you would need to do the following to run the script node listMessagesToCSV.js
import { RestClient } from "@signalwire/node";
import fs from "fs";
"ProjectID",
"Auth Token",
{ signalwireSpaceUrl: "YOURSPACE.signalwire.com" }
Next, we need to create our CSV file, an empty array to put our records into, and an array of headers.
It's important to make sure that later when we loop through the message records, we push the parameters into the CSV in the same order as the headers here. Lastly, we push the headers into the CSV as the first row.
let writeStream = fs.createWriteStream("CompanyNameMessages.csv");
let newLine = [];
const header = [
"Message Sid",
"To",
"From",
"Date Sent",
"Status",
"Direction",
"Price",
newLine.push(header);
Next, we determine which parameters we'd like to filter by and what parameters we expect to be pushed into the CSV.
The filters used in this example are status and start time. When using date time objects in Javascript, it's important to remember that it starts at 0 with 0 being January. Then as we loop through messages
, we push each parameter into the CSV one by one. After we are finished looping through messages
We use writeStream.write
to separate these values by commas and add a new line at the end. Lastly, we use writeStream.end
to close the file.
client.messages
.list({
status: "delivered",
dateSentAfter: new Date(Date.UTC(2021, 4, 1, 0, 0, 0)),
.then((messages) => {
messages.forEach((c) => {
newLine.push(
c.sid,
c.to,
c.from,
c.dateSent,
c.status,
c.direction,
c.price
writeStream.write(newLine.join(",") + "\n", () => {});
writeStream.end();
Java
For the following code to work, you will need to have a Maven project, The Java Wrapper Library and a Signalwire account.
Read about how to get started with the Java Wrapper API here
How to Run Snippet?
Assuming you've named your script MessageList.java
you would need to do the following to run the javac MessageList.java
then java MessageList.java
//Array of message to convert to CSV
public static List<String[]> dataLines = new ArrayList<>();
public static SignalWireClient client() {
return new SignalWireClient("PROJECT-ID-FROM-SPACE",
"API-TOKEN-FROM-SW",
"SPACE-NAME");
In the main
method we need to get our messages using the static client
method, In the full recipe we have an helper method called getMessages
which uses the client().message().getMessages().messages
method to populate messages from your SignalWire Space.
// Load messages from space
List<Message> messages = getMessages();
The getMessages()
method looks like below:
private static List<Message> getMessages() {
// Using the Java Wrapper API call the messages within the project ID
List<Message> messages = client().message().getMessages().messages;
return messages;
Then we make use of the List<Message>
to populate and create a new CSV file using the following lines of code
// Add the header of the CSV file
dataLines.add(new String[]{"From", "To", "Date", "Status", "MessageSID"});
// Populate the item of each message
for (Message message : messages) {
dataLines.add(new String[]{message.from, message.to, message.date_created, message.status, message.sid});
Now all the messages are added to the Variable dataLines
. In the full recipe code we have some helper methods like convertToCsv(String[] data)
public static String convertToCsv(String[] data) {
return Stream.of(data)
.map(MessagesList::escapeSpecialCharacters)
.collect(Collectors.joining(","));
This takes the dataLine array and passes it to createAndPopulateCSV()
which creates a CSV file and then populate the messages
public static void createAndPopulateCSV() throws IOException {
// Auto-generate the name of the file
String filename = "message_result" + System.currentTimeMillis();
// Get the absolute path to the folder you would like to create in the project directory
File file = new File(Paths.get("csv").toAbsolutePath().toUri());
// if file doesn't exist. create a new folder
if (!file.exists()) {
boolean isFolder = file.mkdir();
if (isFolder){
System.out.println("New folder created!");
}else{
System.out.println("Couldn\'t create folder");
// create new csv file with the autogenerated name
File csvOutputFile = new File(Paths.get("csv").toAbsolutePath() + "\\" + filename);
try (PrintWriter printWriter = new PrintWriter(csvOutputFile)) {
dataLines.stream()
.map(MessagesList::convertToCsv)
.forEach(printWriter::println); // Write item into the CSV file
System.out.println("Write operation done successfully!");
to format message in the CSV correctly and handle escape keywords, we make use of the escapeSpecialCharacters()
method
public static String escapeSpecialCharacters(String data) {
String escapeData = data.replace("\\R", " ");
if (data.contains(",") || data.contains("\"")) {
data = data.replace("\"", "\"\"");
escapeData = "\"" + data + "\"";
return escapeData;
In the main method we call the createAndPopulateCSV()
method to start the process of creating the CSV file and populating the file with the message data.
// Generate the CSV file
createAndPopulateCSV();
} catch (IOException exception) {
exception.printStackTrace();
Wrap up
Record keeping is important, so we hope these examples help make it easier to filter your messages and export them to an external CSV with ease. All of these examples will accomplish the same goal and can be built upon to expand or further drill down the amount of data returned. Please feel free to reach out to us on our Community Slack or create a Support ticket if you need guidance!
Updated 12 days ago
