Call & Text By Proxy (Masked Numbers) - Python
This guide will show you how to create a bi-directional mask of participants' phone numbers for voice and text messages using SignalWire and Python.
You will need the Python SignalWire SDK.
How to Run Application
Build and Run on Docker
  1. Use our pre-built image from Docker Hub
docker pull signalwire/snippets-call-text-proxy:python
(or build your own image)
  1. Build your image
docker build -t snippets-call-text-proxy .
  1. Run your image
docker run --publish 5000:5000 --env-file .env snippets-call-text-proxy
  1. The application will run on port 5000
Build and Run Natively
Step by Step Code Walkthrough
Setup Your Environment File
  2. Save new file called .env
Your file should look something like this.
## This is the full name of your SignalWire Space. e.g., example.signalwire.com
SIGNALWIRE_SPACE=
SIGNALWIRE_PROJECT=
SIGNALWIRE_TOKEN=
# The first proxy phone number you'll be using for this guide. Must include the `+1`
SIGNALWIRE_NUMBER_1=+1xxxxxxxxxx
# The second proxy phone number you'll be using for this guide. Must include the `+1`
SIGNALWIRE_NUMBER_2=+1xxxxxxxxxx
Modify Your Proxy Session File
You will need to edit proxy_sessions.json to reflect the correct participant numbers and the SignalWire numbers you choose to wish as proxy numbers.
"Session_Id": "Demo123",
"Participant_A_Number": "+15551237654",
"Participant_B_Number": "+15553883000",
"Proxy_Number": "+15556611212"
"Session_Id": "Demo234",
"Participant_A_Number": "+15555181212",
"Participant_B_Number": "+12347896543",
Configuring the Code
When the /lookup-session route is called, it will look up an active proxy session and create a back-to-back phone call that is proxied, or a proxied text message. LEG A <-> SIGNALWIRE PROXY <-> LEG B
# Lookup a proxy session by proxy number
@app.route('/lookup-session', methods=['GET', 'POST'])
def lookup_session():
# Initialize SignalWire Client
client = signalwire_client(os.environ['SIGNALWIRE_PROJECT'], os.environ['SIGNALWIRE_TOKEN'], signalwire_space_url = os.environ['SIGNALWIRE_SPACE'])
# Read proxy number from request
proxy_number = request.values.get("To")
# Read participant number from request
leg_1 = request.values.get("From")
# read proxy sessions from json file
with open('proxy_sessions.json') as f:
sessions = json.load(f)
# Lookup session, find session that has proxy number and participant that matches
for session in sessions:
# Lookup the second session participant, if A is calling
if session["Proxy_Number"] == proxy_number and session["Participant_A_Number"] == leg_1:
leg_2 = session["Participant_B_Number"]
found = True
break
# Lookup the second session participant, if B is calling
elif session["Proxy_Number"] == proxy_number and session["Participant_B_Number"] == leg_1:
leg_2 = session["Participant_A_Number"]
found = True
break
# We did not find anything yet
found = False
if found == True:
# Check if a CallSid exists, if it does, it is a voice call
if "CallSid" in request.values.keys():
# Bridge legs voice
response = VoiceResponse()
response.dial(leg_2, callerId = proxy_number)
return str(response)
# Check if a MessageSid exists, if it does it is a text message
elif "MessageSid" in request.values.keys():
# Send a message, with challenge code to phone number provided.
from_ = proxy_number,
body = request.values.get("Body"),
to = leg_2
return "200"
else:
# No session found
response.say("We are sorry but your call can not be completed at this time. Good Bye!")
Wrap Up
If you ever had a situation where you wanted to keep your phone number private between two parties, this example will help you out. Services like Lyft and Uber use technology like this every day to help protect the personal phone numbers of both passengers and drivers. There are many use cases for this, and we hope you find it helpful.
Required Resources
