📌 Listing Messages Filtered by Multiple From Numbers
This code snippet will show how you can use the List Messages API to return all messages with a specific list of From numbers.
To quickly run this code, check out our recipe below and replace the variables with your own! Or, keep reading for an in-depth walkthrough.
Python
Read about the different ways to install pandas.
Read about DateTime and how to install using pip.
Read about the SignalWire Python SDK and how to install it.
Code Walkthrough
We will start by importing the necessary resources. In this example, that is datetime, pandas, and the SignalWire Client. We also need to instantiate the SignalWire client using the project ID, auth token, and space URL.
from datetime import datetime
import pandas as pd
In this example, I have included how to filter by a starting date and multiple from numbers. DateSent is a DateTime object where the order for the arguments is Year, Month, Date, Hour, Minute, Seconds. You can leave hour, minute, and seconds at 0, unless you have a specific time of day you would like to filter by.
Next, we need to create two arrays. One will contain all of the from numbers that we want to filter by and the other will be an empty array used for storing message records in greater detail.
from_numbers = ["+1xxxxxxxxxx", "+1xxxxxxxxxx", "+1xxxxxxxxxx", "+1xxxxxxxxxx"]
d = []
Now we will call the List Messages API on each of the from numbers by looping through the array. After the API has stored all the matching records, we will loop through them one by one to gather additional message details about each record and store it in the empty array d that we created above.
for number in from_numbers:
    messages = client.messages.list(from_=number, date_sent_after=(datetime(2021, 10, 0o1)))
    for record in messages:
        d.append((record.from_, record.to, record.date_sent, record.status, record.sid, record.body, record.error_message))
You can expand this to include as many or as few parameters as you'd like. To see all of the parameters returned in the JSON response, you can view our API documentation here: List Messages API
Next, we will create a dataframe using pandas with column name headers. It's important to make sure that the order of the headers matches the order of the parameters you inserted into the array above. If you choose to add more or remove parameters, make sure to double-check that the order matches, or your data will be mismatched in the CSV.
Lastly, we will print the dataframe for debugging purposes and export it to csv. Using the parameter index=False turns off the indexing for each row. You can rename messages.csv to be as specific or general as you'd like.
df = pd.DataFrame(d, columns=('From', 'To', 'Date', 'Status', 'MessageSID', 'Message Body', 'Error Message'))
print('dataframe')
print('\n')
print(df)
df.to_csv('messages.csv', index=False, encoding='utf-8')
Node.js
How to Run Snippet?
If you save this code snippet in a file called listMessagesFilteredByNumbers.js, for example, you then need to run:
node listMessagesFilteredByNumbers.js.
Code Walkthrough
Load the necessary libraries
const fs = require('fs');
const { RestClient } = require("@signalwire/node");
Instantiate the SignalWire Rest Client
In order for us to connect to SignalWire later on in the code using the Rest Client we first need to make sure we update space_url, project_id, and access_token.
let space_url = "YOURSPACENAME.signalwire.com";
let access_token = "PTxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
    project_id,
    access_token,
    { signalwireSpaceUrl: space_url }
Set the numbers to look for
In this step we need to create two arrays: one will contain all of the from numbers that we want to filter by and the other will be an empty array used for storing message records in greater detail.
Make sure to update the from_numbers array with your list of numbers, in E.164 format.
const from_numbers = [
let data = [];
Loop through all of the numbers
For each of the numbers outlined in the previous step, we make use of the List Messages endpoint, through client.messages.list, and specify the from and dateSentAfter parameters.
After we get the list of messages back, we push several fields to the data array.
Only once all of the numbers have been parsed do we get all of the data passed to the data array, and create the allData DataFrame using it. Using DataFrames allows us to easily print all of the message data, as well as export it to a CSV file.
Promise.all(
    from_numbers.map((number) =>
        client.messages
            .list({
                dateSentAfter: new Date(Date.UTC(2022, 01, 01)),
            .then((messages) =>
                messages.forEach((message) => {
                    data.push([
                        message.from,
                        message.to,
                        message.dateSent,
                        message.status,
                        message.sid,
                        message.body,
                        message.errorMessage,
).then(() => {
    let allData = new dfd.DataFrame(data, {
        columns: [
            "From",
            "To",
            "Date",
            "Status",
            "Message SID",
            "Message Body",
            "Error Message",
        config: {
            tableDisplayConfig: {
                columns: [
                    { width: 1 },
                    { width: 13 },
                    { width: 13 },
                    { width: 8 },
                    { width: 9 },
                    { width: 36 },
                    { width: 30 },
                    { width: 13 }
Print the results
Lastly, we print the allData DataFrame to the terminal, and create the Messages.csv file using it.
allData.print();
fs.writeFileSync("Messages.csv", dfd.toCSV(allData));
PHP
For the following code to work, you will need to have the SignalWire PHP SDK installed.
How to Run Snippet?
If you save this code snippet in a file called listMessagesFilteredByNumbers.php, for example, you then need to run:
php listMessagesFilteredByNumbers.php.
Code Walkthrough
We will start by importing the necessary resources. For PHP that involves only the SignalWire REST Client.
use SignalWire\Rest\Client;
So that we can connect to SignalWire using this code, we need to instantiate the SignalWire client using the project ID, auth token, and space URL.
$client = new Client('YOUR-PROJECT-ID', 'YOUR-API-AUTH-TOKEN', array("signalwireSpaceUrl" => "YOUR-SPACE-URL.signalwire.com"));
Set the from numbers to look for
We need to create an array that will contain all of the from numbers that we want to filter by. The numbers listed within this array should be in E.164 format.
// TODO: Update this array with the from_numbers you need results for.
$from_numbers = array("+1416XXXXXXX","+1417XXXXXXX","+1833XXXXXXX",);
Now we will call the List Messages API on each of the from numbers by looping through the array. In this example, I have included how to filter by a starting date for the multiple from numbers. dateSentAfter is a DateTime object where the order for the arguments is Year, Month, Date, Hour, Minute, Seconds. You can leave hour, minute, and seconds at 0, unless you have a specific time of day you would like to filter by. The example is set to look for any messages sent after January 1, 2022. Feel free to comment out the dateSentAfter if it is not needed.
foreach($from_numbers as $number) {
    // Can filter message by whatever parameters you need. This example is any message sent after January 1, 2022.
        "dateSentAfter" => "2022-01-01",
Next, we create an array of header row labels $header_fields to help organize our output file a bit. It's important to make sure that the order of the header labels matches the order of the parameters you insert into the next array we create. If you choose to add more or remove parameters, make sure to double-check that the order matches or your data will be mismatched in the CSV.
We also specify an output file $fp and open it for writing data. You can rename Messages.csv to be as specific or general as you'd like. The header row labels we created are then pushed to this file.
// Write Headers for output CSV.
$header_fields = array('From', 'To', 'Date Sent', 'Status','Message SID', 'Body', 'Error Message');
echo '"'.implode('","', $header_fields).'"'."\n";
// Open File named Messages.csv
$fp = fopen('Messages.csv', 'w');
// Insert headers into output Messages.csv file.
fputcsv($fp, $header_fields);
We'll now create an array $row to hold the parameters we want to output into our file.
Lastly, we will push our array of parameters to the output CSV and close the output file.
    $row = array(
        $message->from,
        $message->to,
        $message->status,
        $message->sid,
        $message->body,
        $message->errorMessage,
      // Insert rows into CSV
    fputcsv($fp, $row);
// close file
fclose($fp);
Java
For the following code to work, you will need to have a Maven project, The Java Wrapper Library and a Signalwire account.
Read about how to get started with the Java Wrapper API here
Read on how to create a Maven project with Intellij here
How to get API Credentials
The API also requires that you authenticate yourself using your Project ID, API Token, and Space URL. If you do not know where to find these values, check out our guide here!
How to Run Snippet?
Assuming you've named your script MessageFromNumber.java you would need to do the following to run the javac MessageFromNumber.java then java MessageFromNumber.java.
Step by Step Code Walkthrough
public static List<String[]> dataLines = new ArrayList<>();
    public static SignalWireClient client() {
        return new SignalWireClient("PROJECT-ID-KEY",
                "API-TOKEN-KEY",
                "SPACE-NAME");
In the main method we need to get our messages the client().message().getMessages().messages method to populate messages from your SignalWire Space.
// List of from number to loop
        String[] listOfNumbers = {"", ""};
        // Return messages from the API
        List<Message> messages = client().message().getMessages().messages;
      // Header of the CSV file
        dataLines.add(new String[]{"From", "To", "Date", "Status", "MessageSID"});
We have an array listOfNumbers used to hold the list of From numbers we would be using to sort result from the API.
Loop through the array of numbers while comparing each element with another for loop that does a comparison with result from the API with the number from our listNumbers array element . if true the element is added to the dataLines used to populate the CSV.
// Loop through multiple phone numbers
        for (int i = 0; i < listOfNumbers.length ; i++) {
          // Loop through the result from the APPI
            for (int j = 0; j < messages.size(); j++) {
              // If {from} number dataset equal to the from value in our API
                if (Objects.equals(messages.get(j).from, listOfNumbers[i])){
                    Message message = messages.get(j);
                  // Add message to the dataLine Array that would be converted to CSV
                    dataLines.add(new String[]{message.from, message.to, message.date_created, message.status, message.sid});
Now that we have the list sorted with an Array holding the informations that need to be exported to a CSV we call the createAndPopulateCSV method which is an help method to create a csv file and write elements into the CSV file.
try{
          // Create a populate the array into CSV
            createAndPopulateCSV();
        }catch (IOException exception){
            exception.printStackTrace();
For full Snippet on the Helper methods you can view the below snippets
createAndPopulateCSV Method
// Create a folder and name of file
    // Populate the file with the dataLine String
    public static void createAndPopulateCSV() throws IOException {
        // Auto-generate the name of the file
        String filename = "message_result" + System.currentTimeMillis();
        // Get the absolute path to the folder you would like to create in the project directory
        File file = new File(Paths.get("csv").toAbsolutePath().toUri());
        // if file doesn't exist. create a new folder
        if (!file.exists()) {
            boolean isFolder = file.mkdir();
            if (isFolder){
                System.out.println("New folder created!");
            }else{
                System.out.println("Couldn\'t create folder");
        // create new csv file with the autogenerated name
        File csvOutputFile = new File(Paths.get("csv").toAbsolutePath() + "\\" + filename);
        try (PrintWriter printWriter = new PrintWriter(csvOutputFile)) {
            dataLines.stream()
                    .map(MessageFromNumber::convertToCsv)
                    .forEach(printWriter::println); // Write item into the CSV file
            System.out.println("Write operation done successfully!");
convertToCsv Method
 // Helper method to convert stream of data to csv
    public static String convertToCsv(String[] data) {
        return Stream.of(data)
                .map(MessagesList::escapeSpecialCharacters)
                .collect(Collectors.joining(","));
escapeSpecialCharacters Method
  public static String escapeSpecialCharacters(String data) {
        String escapeData = data.replace("\\R", " ");
        if (data.contains(",") || data.contains("\"")) {
            data = data.replace("\"", "\"\"");
            escapeData = "\"" + data + "\"";
        return escapeData;
Wrap up
Our List Messages API makes it easy to get lots of detail on your messages, and combined with a few lines of code you can filter the results even more, print them in a more comprehensible way, and export to a CSV file for processing in a spreadsheet!
