Forwarding Inbound Faxes to Email - Python
This short and simple guide will show how you can use the SignalWire Python SDK and the MailGun API in order to forward your incoming SignalWire faxes to email. You can easily bridge this older technology by allowing faxes to be delivered to your inbox with only a few lines of code.
How to Run the Application
To run the application, execute export FLASK_APP=app.py
then run flask run
You may need to use an SSH tunnel for testing this code if running on your local machine. – we recommend ngrok. You can learn more about how to use ngrok with SignalWire here.
To use this Script, you need to expose it to the web (either through ngrok
or by hosting it on a server) and use it as a webhook for handling incoming calls under phone number settings. For example, this is what it looks like if you use an ngrok tunnel to the script. For this script, you would use the given ngrok URL and the /fax-webhook
route, like this http://f0032dfdshhdsfkh7.ngrok.io/fax-webhook
Step by Step Code Walkthrough
Configuring Your Environment File
- Copy from example.env and fill in your values
- Save new file called .env
Your file should look something like this
SIGNALWIRE_SPACE=
SIGNALWIRE_PROJECT=
SIGNALWIRE_TOKEN=
# The phone number you'll be using. Must include the `+1` ,
SIGNALWIRE_NUMBER=
MAILGUN_DOMAIN=
MAILGUN_API_TOKEN=
# Send Email From Address
[email protected]
# Send email To address
[email protected]
# Email subject
EMAIL_SUBJECT=Forward Fax To Email
Configuring the main script
We start with the necessary imports and instantiate a Flask app:
import os
import requests
import pprint
from dotenv import load_dotenv
load_dotenv()
app = Flask(__name__)
Next, we need to define a function that will use the MailGun API to send the email. You can read more about sending with the MailGun API in their documentation here.
This function is very simple and copied exactly from their documentation - no need to make any difficult changes! Set up the API token, from address, to address, and subject line in your .env
file. We will show you how to set that up further down in the guide! The body will be passed in as a variable to the function when an incoming fax is received and the webhook is used.
def send_email(body):
return requests.post(
"https://api.mailgun.net/v3/" + os.environ['MAILGUN_DOMAIN'] + "/messages",
auth=("api", os.environ['MAILGUN_API_TOKEN']),
data={"from": os.environ['EMAIL_FROM'],
"to": [os.environ['EMAIL_TO']],
"subject": os.environ['EMAIL_SUBJECT'],
"text": body})
We also need to define the route we will be using to accept incoming GET/POST requests. In this route, we will call our send_email
function created above with the formatted form data in the fax as the body. We will then return "200" to signify it was successful.
@app.route('/fax-webhook', methods=['POST'])
def fax_webhook():
send_email(pprint.pformat(request.form, indent=4))
return "200"
Finally, we run the application:
app.run()
Wrap Up
This guide demonstrates how easy it can be to forward your faxes to email using the Mailgun API and SignalWire Python SDK allowing for review of faxes from anywhere.
Required Resources:
Updated 23 days ago
