Two Factor Authentication for Voice - Python
By adding 2FA to your application, you can provide your users effective protection against many security threats that target user passwords and accounts. It will generate a One-Time Password to their phone number via voice call. Application developers can enable two-factor authentication for their users with ease and without making any changes to the already existing application logic or database structure! This guide uses the Python SignalWire SDK to show an example of how that can be done!
Find the full code on Github here
You will need a signalwire account which you can create here. You will also need your SignalWire API credentials which you can find in the API tab of your SignalWire Dashboard. For more information, read our guide to Navigating your SignalWire Space.
Additionally you will need the SignalWire Python SDK, the Requests module, and Flask
How to Run this Application
Setup Your Environment File
  2. Save new file called .env
Your file should look something like this
SIGNALWIRE_SPACE=
SIGNALWIRE_PROJECT=
SIGNALWIRE_TOKEN=
# The phone number you'll be using for this guide. Must include the `+1` , e.g.: +15551234567
SIGNALWIRE_NUMBER=
Build from Docker Hub
docker pull signalwire/snippets-voice-two-factor-auth:python
(or)
Build your Own Docker Image
docker build -t snippets-voice-two-factor-auth
(then)
Run your image
docker run --publish 5000:5000 --env-file .env snippets-voice-two-factor-auth
  1. The application will run on port 5000
Build and Run Natively
Step-by-Step Walkthrough
In the Github Repo you will find the Readme.md, License, and a python folder.
In the python folder there is a Dockerfile, our example.env file for our environment variables, and the app.py file where our application lives.
Into the code
We need to start by creating variables to store all the data from the authentication session.
data = {}
data['requests'] = []
Code Verification
Next, we will define a function that looks up the phone number and verifies that the code is correct. We will loop through all authentication sessions, and check if there is a matching number while first adding a + to make sure the number is in E164 format. If there is a session matching that number, we will complete our second check to see if the code they provided was correct. If both conditions are satisfied, we will remove the validated session from the data dictionary created above.
def lookup_code(number,code):
# Loop through all sessions
for i in range(len(data['requests'])):
# Look if number is equal to a number in a session, we are prepending a '+'
if '+' + number == data['requests'][i]['number']:
# Great, We found a session matching that number, now let us check the challenge code
if code == data['requests'][i]['code']:
# We have a match, let's remove the validated session and return true
data['requests'].pop(i)
return True
# Catch all for failed challenges
return False
Flask Routes Setup
Validate-Auth
Now that we have defined our variables and our functions, we need to move on to the Flask routes! We will start by defining a route called /validate-auth that will validate the authentication request. We will grab the authorization code and the phone number from the GET/POST request and call our previously defined lookup_code(number, code) function. If the lookup & authentication are successful, we will return a 200OK. If the lookup is unsuccessful, we will return a 403 FORBIDDEN.
# Listen for '/validate-auth' route
@app.route('/validate-auth')
def validate_auth():
# Grab the authorization code from the GET/POST request
check_code = request.values.get('auth_code')
# Grab the phone number from the GET/POST request
number = request.values.get('number')
# Verify the number and challenge code
if lookup_code(number, check_code):
# Return 200, On Accept
return "200"
# Return 403, On Forbidden
return "403"
Request-Auth
The next route we define is what will be called when you want to create an authentication request. We start by instantiating the SignalWire client using the Project ID, Auth Token, and Space URL. Then we will generate a random 6 digit code between 123456 and 987654. Next, we get the phone number that we're going to send the call to and add both the code and number to our global data object. Lastly, we will use the Create Call API in order to send a call to the requested number with the generated code.
@app.route('/request-auth', methods=['GET', 'POST'])
def request_auth():
client = signalwire_client(os.environ['SIGNALWIRE_PROJECT'], os.environ['SIGNALWIRE_TOKEN'], signalwire_space_url = os.environ['SIGNALWIRE_SPACE'])
auth_code = str(random.randint(123456,987654))
number = "+" + request.values.get('number')
data['requests'].append({
'number': number,
'code': auth_code
call = client.calls.create(
from_ = os.environ['SIGNALWIRE_NUMBER'],
url = "http://" + os.environ['HOSTNAME'] + "/call_2fa?auth_code=" + auth_code,
to = number
return "200"
Call_2fa
Our last route will be used in order to read out the authorization code over the phone call. We will start by getting the auth code from the query params passed in when creating the call in the previous route. We will also instantiate VoiceResponse() so that we can use text to speech. Lastly, we will use text to speech to repeat the authorization code twice for the end user and then hang up!
@app.route('/call_2fa', methods=['GET', 'POST'])
def call_2fa():
auth_code = request.values.get('auth_code')
response = VoiceResponse()
response.say('Your authorization code is: ' + auth_code )
response.say('Repeating...')
response.say('Thank you for calling, GoodBye!')
return str(response)
Wrap Up
Two Factor Authentication is a great tool and this guide demonstrates how easy it is to integrate an extra layer of protection into your projects using the SignalWire python SDK.
Multi-Factor Authentication API Endpoints
SignalWire does offer MFA endpoints you can learn about HERE to request a Multi-Factor Auth Token via SMS, request a Token via phone call, and verify tokens. This is a great option that works right out of the box if you don't need to control how it works under the hood.
Github Repo
Python SignalWire SDK Ngrok
