Summarizing Voice Usage
In this snippet, we will show you how to use SignalWire's List Calls API to gain valuable insight into your usage of voice on SignalWire's platform. After running this script, you gain both itemized and bird's eye views on all of the details of your voice usage, including:
  • The "To" and "From" number.
  • The time the call started.
  • The call SID.
  • The price of the call.
  • The call direction.
  • Whether the call was answered by a human or an answering machine.
  • The call status.
While this snippet will provide you with a lot of information, it can easily be manipulated to discover more! Take a look at our API Documentation to find out more.
As we will be using Python for this script, you will need to install the SignalWire Python SDK. Once installed, you will also need your SignalWire API credentials, including an API Token, SignalWire Space URL, and a Project ID. Find this information on the API Credentials page page of your SignalWire Dashboard.
You will need to have a few different Python Packages installed as well to achieve this.
  • DateTime for creating an ability to filter by a specific time frame.
  • Pandas for creating data frames and making it easier to manage large quantities of data.
Full code example: Using the List Calls API to Get Voice Statistics
from datetime import datetime
import pandas as pd
client = signalwire_client("ProjectID", "AuthToken", signalwire_space_url='example.signalwire.com')
calls = client.calls.list(start_time_after=datetime(2021, 10, 1), start_time_before=datetime(2021, 10, 31))
d = []
status = []
for record in calls:
d.append((record.from_, record.to, record.start_time, record.sid, record.price, record.direction, record.answered_by, record.status))
status.append(record.status)
total_queued=int(status.count("queued"))
total_ringing=int(status.count("ringing"))
total_in_progress=int(status.count("in progress"))
total_canceled=int(status.count("canceled"))
total_completed=int(status.count("completed"))
total_busy=int(status.count("busy"))
total_failed=int(status.count("failed"))
num_outbound_calls = int(calls.count("outbound"))
num_inbound_calls = int(calls.count("inbound"))
df = pd.DataFrame(d, columns=('From', 'To', 'Start Time', 'Call SID', 'Price', 'Call Direction', 'Answered By', 'Call Status'))
print(df)
df.to_csv('Calls.csv', index=False, encoding='utf-8')
print()
totalCalls = len(df)
totalCost = df['Price'].sum()
formattedCost = "${:,.2f}".format(totalCost)
print("You sent " + str(totalCalls) + " total calls during your selected date range.")
print("The total cost of calls in your selected date range is approximately " + formattedCost + " USD.")
print("There are currently " + str(total_queued) + " calls in the queue, with " + str(total_ringing) + " currently ringing and " + str(total_in_progress) + " currently in progress.")
print("There have been " + str(total_canceled) + " calls that have been canceled.")
print("There have been " + str(total_completed) + " completed calls, " + str(total_busy) + " calls marked as busy, and " + str(total_failed) + " failed calls.")
print("There were " + str(num_inbound_calls) + " inbound calls and " + str(num_outbound_calls) + " outbound calls.")
Code Breakdown
The first thing we'll do is import all of the resources we spoke about earlier and instantiate the client. From there, we call the List Calls API as you can see below. Notice that datetime is called and uses the format datetime(YYYY, MM, DD). This tells the script over what time period you wish to examine and gain insight from this project.
import pandas as pd
Once we complete that, next we're going to create an array and loop through all of the calls based on the desired time frame we set earlier and then append any additional data that we wish to use as it's looping. We then categorize the status of the calls in order to quantify the calls in various statuses.
d = []
status = []
Next we'll use the toolset given to us by installing Pandas to create a data frame that will organize this information into a much more manageable and readable format. Notice the line df.to_csv('Calls.csv', index=False, encoding='utf-8'). This line exists to export the itemized data frame that this snippet provides you with to a CSV file. After, we total up the individual prices of each call in order to provide a real-time total price that resulted from your Voice API usage.
print(df)
print()
The final portion of this snippet prints a more holistic summary of what your Voice API usage has been based off the dates you've provided to the List Calls API, giving you insight of the total price of the calls, the total number of calls inbound and outbound, and how those calls performed.
When all is said and done, your console will look like the image below, giving you that bird's eye view of your voice usage in that project. If you wish to see the itemized table that gives you full detail into every call, simply search for the CSV file on your computer that exported as a result of that script.
The output looks like the following:
From                       ...   Call Status
0 sip:+12147903161@sip.signalwire.com ... completed
1 +12147903161 ... completed
[2 rows x 8 columns]
You sent 2 total calls during your selected date range.
The total cost of calls in your selected date range is approximately $0.26 USD.
There are currently 0 calls in the queue, with 0 currently ringing and 0 currently in progress.
There have been 0 calls that have been canceled.
There have been 2 completed calls, 0 calls marked as busy, and 0 failed calls.
There were 0 inbound calls and 0 outbound messages.
Process finished with exit code 0
Conclusion
Running this script will provide you with valuable KPIs to reflect how you and your team utilize SignalWire's very powerful Voice API, giving you the performance, direction, and prices of every call that has occurred in a given SignalWire Space.
If you would like to test this example out, create a SignalWire account and Space. Please feel free to reach out to us on our Community Discord here or create a Support ticket if you need guidance!
