Hang Up Call
The Hang Up Call node will disconnect a call and end the flow.
note
This node is not strictly required, as calls will automatically end when the call reaches the end of a flow.
The Reason parameter is used for logging purposes and does not change the behavior of the Hang Up Call node.
Node Settings​
ParameterDescription
ReasonThe reason for hanging up the call.
Possible Values: Busy, Decline, Hang up
Default Value: Busy
