Using Video with React Native
Introduction
If you want to build a video-conferencing application on mobile, you can integrate the Video API inside any React Native application. In particular, you can use the JavaScript Video SDK almost as you would on the web.
In this guide, we will show you how to integrate the Video API into your React Native application. As a reference, you can take a look at our GitHub repository, which contains a demo videoconferencing application written in React Native. Please note that currently the react-native support is experimental.
If you just want to try out the demo application, follow the instructions in the README file.
Prerequisites
In this guide we will assume a basic knowledge about our JavaScript Video SDK. If you want to know more about it, take a look at Getting Started with the Video API and then come back to follow this guide.
We will also assume some basic knowledge about React Native.
Creating the application
We are going to create a new React Native application. If you don't already have one, from the shell run:
npx react-native init MyMobileVideoApp
This will create a folder, MyMobileVideoApp, with some boilerplate code.
We need to install the following dependencies:
  • @signalwire/js: the SignalWire Video SDK
  • react-native-webrtc: WebRTC implementation for React Native
  • react-native-get-random-values: a compatibility dependency
  • react-native-incall-manager: to handle actions and events during a call as if it was a native one
cd MyMobileVideoApp
yarn add @signalwire/js react-native-webrtc react-native-incall-manager
For iOS, we also need to install the native modules:
cd ios
pod install
For Android, we need to increase the minSdkVersion from 21 to at least 24 (see this upstream issue). To do that, open the file android/build.gradle and set minSdkVersion = 24.
You can test the empty application with npm run ios or npm run android.
Setting up the permissions
Before delving into the code, we are going to configure our iOS and Android applications to require permissions for the camera and for the microphone.
iOS
For iOS, open the file ios/MyMobileVideoApp/Info.plist and add the following entries right before <key>NSLocationWhenInUseUsageDescription</key>:
<key>NSCameraUsageDescription</key>
<string>Allow camera access so that others can see you during meetings</string>
<key>NSMicrophoneUsageDescription</key>
<string>Allow microphone access so that others can hear you during the meeting</string>
Android
For Android, open the file android/app/src/main/AndroidManifest.xml and add the following entries:
<uses-permission android:name="android.permission.ACCESS_NETWORK_STATE" />
<uses-permission android:name="android.permission.BLUETOOTH" />
<uses-permission android:name="android.permission.CAMERA" />
<uses-permission android:name="android.permission.MODIFY_AUDIO_SETTINGS" />
<uses-permission android:name="android.permission.RECORD_AUDIO" />
<uses-permission android:name="android.permission.SYSTEM_ALERT_WINDOW" />
<uses-permission android:name="android.permission.WAKE_LOCK" />
Adding basic video functionality
We are going to add some basic video functionality to the App.js component. First, we import the libraries:
import 'react-native-get-random-values';  // this must be imported at the very
                                          // top of the file, before any other
                                          // import
import * as SignalWire from '@signalwire/js';
import { RTCView } from 'react-native-webrtc';
import InCallManager from 'react-native-incall-manager';
Then, we add some state variables to our main component:
const [stream, setStream] = React.useState(null);
const [roomSession, setRoomSession] = React.useState(null);
The stream variable will hold a reference to the remote stream, while roomSession will contain the RoomSession object from which we can access methods such as audioMute() and videoMute().
Then, we are going to add to the template the WebRTC View in which the video stream will be displayed. Our template will be something like this, which also include a "Join" button:
    <SafeAreaView>
      <RTCView
        streamURL={stream?.toURL?.()}
        style={{
          width: '100%',
          height: 300,
          backgroundColor: 'black'
    </SafeAreaView>
    <Button onPress={join} title="Join" />
The "Join" button depends on a function join. This is mostly standard Video SDK code, and looks like this:
async function join() {
  // We instantiate a room session. The user name and the room name are
  // determined by the token.
  const room = new SignalWire.Video.RoomSession({
    token: '<YourVideoRoomToken>',
    logLevel: 'silent'
  // Store the room session object in the state of this component.
  setRoomSession(room)
  // Start the InCallManager to make the system know we are in a call.
  InCallManager.start({ media: 'audio' });
  // When we receive the event indicating that we have joined the session,
  // take the remote stream object and store it in the state variable.
  room.on('room.joined', params => {
    console.debug('>> EVENT room.joined', params);
    setStream(room.remoteStream);
  // Actually join the room
  await room.join()
Note that we have left <YourVideoRoomToken> as a placeholder. To avoid over-complicating this guide, we will obtain a Video Room Token manually via cURL, and we will hardcode that into our component. In a real application, you would obtain the token from a remote server. Run from your shell the following cURL command to obtain the token:
curl --request POST \
     --url 'https://your_space_id.signalwire.com/api/video/room_tokens' \
     --user 'project_id:api_token' \
     --header 'Content-Type: application/json' \
     --data '{"user_name": "john", "room_name": "office"}'
Make sure to replace the placeholders your_space_id, project_id, and api_token, whose values you can find in your SignalWire Space.
It's time to compile. Try building the application: you should be able to join a room.
The video application running in the iPhone simulator.The video application running in the iPhone simulator.
Leaving the room
We are now going to add a new button to leave the room. Let's add a leave function to leave the session and to perform some cleanup:
async function leave() {
    await roomSession?.leave();
    if (stream) {
      stream.release();
      setStream(null);
      setRoomSession(null);
      InCallManager.stop();
  } catch (e) { }
Then we can use the function in a new button:
<Button onPress={leave} title="Leave" />
At this point, our whole component should look like this:
import React from 'react';
import {
  SafeAreaView,
  Button,
} from 'react-native';
const App = () => {
      logLevel: 'silent'
    await room.join()
      if (stream) {
        stream.release();
        setStream(null);
    } catch (e) { }
  return (
    <SafeAreaView>
      <RTCView
        style={{
          width: '100%',
          height: 300,
    </SafeAreaView>
export default App;
Screen sharing
Screen sharing is also supported, but it requires several additional steps for both Android and iOS. Please refer to our GitHub repository at https://github.com/signalwire/video-sdk-react-native-demo for up-to-date instructions on how to integrate screen sharing, and for a working example.
Wrap up
We have demonstrated step-by-step how to integrate the SignalWire JavaScript SDK into a React Native application. For more information on the usage of the JavaScript SDK, take a look at the following resources:
