📌 Releasing Project Numbers from a CSV
The Python script example below will delete numbers from your SignalWire Space based on a CSV file of the intended numbers to be deleted.
At some point, you may need to release a large quantity of numbers in order to purchase new ones. This can be tedious to delete one by one, so this example shows one way that you can release numbers in bulk with ease.
To quickly run this code, check out our recipe below and replace the variables with your own! Or, read our step by step walkthrough to learn more about this snippet!
What are we going to do?
This code snippet will read a CSV of numbers that you want to delete, compare it with the full list of numbers within your project, and release all the ones that match the CSV. Please note: the CSV file containing the numbers to be deleted must be in the same folder as the below script.
Python
For this code, the SignalWire Python SDK will need to be installed. It can be accessed here: SignalWire Python SDK Documentation.
What do you need to replace in this code?
ProjectID - Your project ID is an alphanumeric string that tells the SignalWire SDK where to find your project. You can find this in an easily copyable format by going to yourSignalWire Portal and clicking the API tab on the left hand side.
YOURSPACE - Your space URL is the domain of your space, i.e. example.signalwire.com. This can also be found in an easily copyable format within the API tab in your SignalWire space.
You will need to replace the name ‘Numbers.csv’ with the name of your CSV file.
Code Walkthrough
Load required libraries
import csv
Instantiate the SignalWire Client
In order to successfully connect to SignalWire's servers, make sure to replace ProjectID, AutoToken, and YOURSPACE.
client = signalwire_client("ProjectID", "AuthToken", signalwire_space_url='YOURSPACE.signalwire.com')
Get numbers and print them
incoming_phone_numbers = client.incoming_phone_numbers.list()
print("Total Numbers -- " + str(len(incoming_phone_numbers)))
Open CSV file and add numbers to results array
Please Note
The CSV file containing the numbers to be deleted must be in the same folder as the script. Otherwise, you will need to specify the proper path to your CSV when opening the file.
results = []
with open("Numbers.csv", 'r', encoding='utf-8-sig') as csvfile:
    reader = csv.reader(csvfile)
    # Change to E164 format if it's not already in that format
    for row in reader:
        if "+" not in row[0]:
            results.append("+" + row[0])
        else:
            results.append(row[0])
print(results)
Loop through all account numbers, and release each of them if it exists in the Results array
for record in incoming_phone_numbers:
    if record.phone_number in results:
        print("deleting number -- " + record.phone_number)
        client.incoming_phone_numbers(record.sid).delete()
Getting Started Guide
