IVR with Voicemails Forwarded to Email - Node.js
This advanced example builds an application that implements a simple phone tree IVR with a few interesting features, including:
- Parallel dialing to multiple phone numbers
- Recording a voicemail and using a dynamic greeting
- Transcribing voicemail and sending both the text and the recording via email
Check out the full code on our Github Repository here
You will need the SignalWire Node.JS SDK, and your SignalWire Credentials. You can find these by logging into your SignalWire space and navigating to the API tab. For more information on navigating your SignalWire space check here
The application also uses the Express web framework and Mailgun to send the emails, and you will need an API key from that service. You could also use any other email API.
Running the application
Setup Your Environment File
- Copy from example.env
- Save new file called .env
- Fill in the fields with your own values
PRIMARY_SALES=+15557788999
SECONDARY_SALES=+15554433222
RECRUITERS_GROUP=+15556677888,+15559998877
ACCOUNTING_GROUP=+15554455777
[email protected]
[email protected]
[email protected]
MAILGUN_DOMAIN=your-Mailgun-domain
MAILGUN_API_KEY=your-Mailgun-api-key
Build and run via Docker
It is simpler to run the application via Docker, by first building the image with docker build -t nodeivr .
followed by docker run -it --rm -p 3000:3000 --name nodeivr --env-file .env nodeivr
Build and Run locally
If you are running the application locally, first load the .env
file with set -o allexport; source .env; set +o allexport
, then run npm install
followed by npm start
You may need to use a SSH tunnel for testing this code if running on your local machine. – we recommend ngrok. You can learn more about how to use ngrok here.
When you configure a SignalWire number to test, you should add
/entry
to the end of the URL you input, such ashttps://yourname.ngrok.io/entry
.Otherwise, simply head to
http://localhost:3000
Step by Step Code Walkthrough
In the Github Repo there are 6 files. We are mainly concerned with the env.example
which we will use to set up our .env
file, and index.js
where the application lives.
Entry
The core of the application is the entry
route, where we ask for the user's choice via DTMF.
app.post("/entry", (req, res, next) => {
var response = new RestClient.LaML.VoiceResponse();
gather = response.gather({ timeout: 5, numDigits: 1, action: formatUrl('mainmenu') })
gather.say("Hello! Press 1 for sales, 2 for recruiting or 4 for accounting.")
respondAndLog(res, response);
The SignalWire Compatibility APIs require that code is translated into XML, so here is the XML version of what the code above does!
<Gather timeout="5" numDigits="1" action="/mainmenu">
<Say>Hello! Press 1 for sales, 2 for recruiting or 4 for accounting.</Say>
</Gather>
MainMenu
Based on what number the user inputs, we then redirect to the correct action in the mainmenu
handler. Whether the user dials sales, recruiting, or accounting, you can see below that we dial every member of the group at the same time. When one person picks up, the rest of the calls will be terminated.
app.post("/mainmenu", (req, res, next) => {
console.log(req.body);
switch (req.body.Digits) {
case "2":
dial = response.dial({timeout: 20, action: formatUrl('voicemail', "?Email=" + JOBS_EMAIL + "&Message=Recruiting")});
var recruiters = RECRUITERS_GROUP.split(',')
recruiters.forEach(function(item) {
dial.number(item);
break;
case "4":
dial = response.dial({timeout: 20, action: formatUrl('voicemail', "?Email=" + ACCOUNT_EMAIL + "&Message=Accounting")});
dial.number(ACCOUNTING_GROUP);
break;
default:
dial = response.dial({timeout: 20, action: formatUrl('primarysalesdial')});
dial.number(PRIMARY_SALES);
For example, if the caller enters 2
, this is the XML that is returned. Multiple <Number>
entries are dialed at the same time, the first one to pick up hangs up the other.
<Dial timeout="20" action="/[email protected]&Message=Recruiting">
<Number>+15556677888</Number>
<Number>+15559998877</Number>
</Dial>
Action parameters
What is very important here is the action
parameter in each dial. The voicemail
URL is what will be triggered when a call ends, and we will need to check if the call had actually connected to the intended department or not. If not, we will send them to voicemail. Note that we also pass the department name via query string so the greeting is dynamic.
app.post("/voicemail", (req, res, next) => {
if (req.body.DialCallStatus != "completed") {
// it means the call was not answered
response.say("Our " + req.query.Message + " department is currently unavailable. Please leave a message after the beep.")
action = formatUrl('voicemailhandler', "?Email=" + req.query.Email)
response.record({transcribe: true, transcribeCallback: action, action: action })
generating the following XML:
<Say>Our Accounting department is currently unavailable. Please leave a message after the beep.</Say>
<Record transcribe="true" transcribeCallback="/[email protected]" action="/[email protected]"/>
In the above, we set a transcribeCallback
for the <Record>
action. This allows our callback to receive both the recording file URL and the transcription text.
Handling the transcription is made a bit tricky by the fact that it is asynchronous, so the handler gets called twice, once for the recording URL and once for the transcription. We get around that by temporarily saving the recording in a hash in memory. In a production environment, this should be replaced by a database.
Sending our transcription to email with Mailgun
When the second request comes with the transcription, we use Mailgun to send an email containing the recording file and the recording transcription.
app.post("/voicemailhandler", (req, res, next) => {
if (req.body.TranscriptionText) {
console.log("Got transcription, send email " + req.query.Email + RECORDING_DB[req.body.CallSid] + req.body.TranscriptionText);
emailTranscription(req.query.Email, RECORDING_DB[req.body.CallSid], req.body.TranscriptionText, req.body.From);
// avoid leaking memomry
delete RECORDING_DB[req.body.CallSid];
} else if (req.body.RecordingUrl) {
console.log('stash recording for later');
RECORDING_DB[req.body.CallSid] = req.body.RecordingUrl
Wrap Up
This guide takes look into how the SignalWire API can be used to handle parallel dialing as well as recording and transcribing voicemail. Then sending those voice mail transcriptions and recordings with the help of MailGun!
Github
Express
Mailgun
Updated 28 days ago
