Multi Factor Authentication for Voice - Ruby
Multi-factor authentication (MFA) is used to authenticate users of an application through the use of a secret token that is sent to them over SMS text or a voice call. It is commonly used for logging in to secure systems, but it is also gaining popularity as a one-time password (OTP) mechanism to authorize transactions or to sign documents and contracts.
SignalWire's Multi-Factor Authentication provides a simple and secure flow to request and verify tokens via REST HTTP calls. This application implements a simple flow to showcase how the API operates in a Ruby environment.
What do I Need to Run this Code?
You can view the full code on our GitHub HERE
The SignalWire Ruby SDK will need to be installed.
Your SignalWire credentials (API Token, Space URL, and Project ID) can all be found in an easily copyable format within the API tab of your SignalWire portal. For more information on navigating your Space check out this guide.
Lastly, you will need to install some additional Ruby packages:
  • Sinatra for quickly creating web applications in Ruby
  • Dotenv for managing our environment variables
How to Run the Application
Build using Docker
build the container using docker build . -t mfaruby then run the application with docker run -it --rm -p 4567:4567 --name mfaruby --env-file .env mfaruby.
Build Natively
If you are running the application with Ruby on your computer, set up the .env file and then run bundle install followed by bundle exec ruby app.rb.
Step by Step Code Walkthrough
Set up your .env file
  2. Save new file called .env
Your file should look something like this.
SIGNALWIRE_PROJECT_KEY=yourproject
SIGNALWIRE_TOKEN=yourtoken
SIGNALWIRE_SPACE=YOURSPACE.signalwire.com
Walk through app.rb
Our application is going to be heavily based off of the Ruby translation of the SignalWire Multi-Factor Authentication API so we must begin by requesting a token via phone call. Notice how the base of the request for a MFA token can be seen in the Ruby snippet below.
def make_request(action, payload)
uri = URI.parse("https://#{ENV['SIGNALWIRE_SPACE']}/api/relay/rest/mfa#{action}")
request = Net::HTTP::Post.new(uri)
request.basic_auth(ENV['SIGNALWIRE_PROJECT_KEY'], ENV['SIGNALWIRE_TOKEN'])
request.set_form_data(payload)
response = Net::HTTP.start(uri.hostname, uri.port, use_ssl: uri.scheme == "https", verify_mode: OpenSSL::SSL::VERIFY_NONE) do |http|
http.request(request)
end
if response.code.to_i < 400
return JSON.parse(response.body)
else
return { "success" => false }
end
end
Next, we must verify that the token was entered correctly. For this, we will look at the SignalWire MFA API for verifying a token. To make this request with the ruby definition below, we simple change the mfa#{action} to verify and send the token
The next step in our code will be to perform these two API calls under the same branch so that we can request and verify the same authentication code.
From the make_request definition declared above, we can see the application requesting a token from the post request beginning on line 8 of the snippet below.
Next, we see the modification of the make_request function for verification of the token. Notice how the API is still sending a post request but the URI is appended with /verify and our payload is the token rather than the to number being sent with the API.
get '/' do
erb :index
end
post '/' do
if params[:phone]
# request the token
payload = {
"to" => params[:phone]
result = make_request("/#{params[:mode]}", payload)
@verify = result["id"]
elsif params[:verify]
# request verification of the token
payload = {
"token" => params[:code]
result = make_request("/#{params[:verify]}/verify", payload)
@success = result["success"]
@verify = params[:verify]
end
erb :index
end
Wrap Up
Multi-factor authentication adds security to your application by requesting a user to be verified via voice or via text message which sounds like exhausting work if you have to sit on your phone all day and manually send each one of your customers a token.
The One Time Password flows (OTP) from SignalWire's MFA API allows you to easily automate this process and beef up your security systems with just a few lines of Ruby code.
Required Resources:
