📌 Listing Numbers to a CSV
List all of the numbers in your SignalWire Project and export them to CSV
This snippet might be helpful to you if you need to separately store a list of all your SignalWire numbers within a project. You can use one or more of the following parameters to further filter your records and return only the specific information that you need: FriendlyName
, Origin
, PhoneNumber
To quickly run this code, check out our recipe below and replace the variables with your own! Or, read our code walkthrough to learn more about this snippet!
What are we going to do?
With this code we will be querying your project and returning all of the numbers in your project, limited by whatever parameters you choose to use. We will then take this data and insert it into a CSV for your records or further use.
Python
You MUST have pandas installed and imported for this to work. pandas is required to create the dataframe and export it to CSV.
You must have the SignalWire Python SDK installed. You can install that here.
What do you need to replace in this code?
ProjectID
- Your project ID is an alphanumeric string that tells the SignalWire SDK where to find your project. You can find this in an easily copyable format by going to your SignalWire Portal and clicking the API tab on the left-hand side.
AuthToken
- Your Auth Token is an alphanumeric string that helps to authenticate your HTTP requests to SignalWire. You can create this (if you haven’t already) or copy this in an easily copyable format by going to your SignalWire Portal and clicking the API tab. If you have not created an API token, press the blue new button. If you have, click show and copy the string.
SpaceURL
- Your space URL is the domain of your space, i.e. example.signalwire.com. This can also be found in an easily copyable format within the API tab in your SignalWire space.
If you want to add a parameter that you can filter the numbers by, you can add it within client.incoming_phone_numbers_list()
Code Walkthrough
Load libraries and instantiate SignalWire Client
import pandas as pd
client = signalwire_client("ProjectID", "AuthToken", signalwire_space_url = 'SpaceUrl')
Fetch all numbers in your project and add them to an array
incoming_phone_numbers = client.incoming_phone_numbers.list()
# Sets up an empty array
d = []
# Appends incoming phone numbers into
for record in incoming_phone_numbers:
d.append((record.phone_number, record.sid))
print(d)
Create dataframe, print it, and export to CSV
# Puts message log array into dataframe with headers for easier reading.
df = pd.DataFrame(d, columns=('Phone Number', 'PhoneNumberSID'))
print('dataframe')
print('\n')
print(df)
# Exports dataframe to csv, index=False turns off the indexing for each row
df.to_csv('Numbers.csv', index=False, encoding='utf-8')
Getting Started Guide
Updated 13 days ago
