📌 Listing Messages with a Specific Error Code to CSV
These code snippets show how you can use SignalWire's Compatibility API to filter the messages in your project by any given error code, and then export the message data into a CSV for your own record keeping or for passing to our Support team.
To quickly run this code, check out our recipe below and replace the variables with your own! Or, keep reading for an in-depth walkthrough.
Python
Read about the different ways to install pandas here.
Read about datetime and how to install using pip here.
Read about the SignalWire Python SDK and how to install here.
How to Run Snippet?
If you copy the code and save it to a file named listMessagesWithSpecificError.py
, for example, to run it you will need to run:
- MacOS/Linux -
python3 listMessagesWithSpecificError.py
- Windows -
py listMessagesWithSpecificError.py
Code Walkthrough
Load the necessary libraries and instantiate the SignalWire Client
We will start by importing the necessary resources. In this example, that is datetime, pandas, and the SignalWire Client. We also need to instantiate the SignalWire client using the project ID, auth token, and space URL.
from datetime import datetime
import pandas as pd
Get the list of messages
In this example, I have included how to filter by DateSent
and the from
number. DateSent
is a DateTime object where the order for the arguments is Year, Month, Date, Hour, Minute, Seconds. You can leave hour, minute, and seconds at 0, unless you have a specific time of day you would like to filter by. Error code is not something you can filter by directly in the List Messages API - that filtering will come later in the code instead!
We will call the List Messages API filtering by date and from number to narrow down the results. If you send at a very high volume and do not try to filter down further by date or from number or some other factor, you may find that the code takes a very long time to compile.
messages = client.messages.list(date_sent=datetime(2021, 11, 8),
from_="+1xxxxxxxxxx",
Add messages with matching error code to an array
Next, we will create an empty array d
to store all the filtered messages with a specific error code. We will loop through each individual message record that was returned and if it matches the specific error code we are looking for, we will append it to d
. You can read more about the possible error codes to look for here.
d = []
for record in messages:
if record.error_code == 30022:
d.append((record.from_, record.to, record.date_sent, record.sid, record.error_code))
You can expand this to include as many or as few parameters as you'd like. To see all of the parameters returned in the JSON response, you can view our API documentation here: List Messages API
Create the DataFrame, print it, and export to CSV
Next, we will create a dataframe using pandas with column name headers. It's important to make sure that the order of the headers matches the order of the parameters you inserted into the array above. If you choose to add more or remove parameters, make sure to double-check that the order matches, or your data will be mismatched in the CSV.
Lastly, we will print the dataframe for debugging purposes and export it to csv. Using the parameter index=False
turns off the indexing for each row. You can rename messages.csv to be as specific or general as you'd like.
df = pd.DataFrame(d, columns=('From', 'To', 'Date', 'MessageSID', 'Error Code'))
print('dataframe')
print('\n')
print(df)
df.to_csv('messages.csv', index=False, encoding='utf-8')
Node.js
- Danfo.js
- fs - there is no need to install this module, as it is part of the Node.js Core
- SignalWire Rest Client
How to Run Snippet?
If you save this code snippet in a file called listMessagesWithSpecificError.js
, for example, you then need to run:
node listMessagesWithSpecificError.js
Code Walkthrough
const fs = require('fs');
const { RestClient } = require("@signalwire/node");
Instantiate the SignalWire Rest Client
In order for us to connect to SignalWire later on in the code using the Rest Client we first need to make sure we update space_url
, project_id
, and access_token
// TODO: Update with your credentials
let space_url = "YOURSPACENAME.signalwire.com";
let access_token = "PTxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
project_id,
access_token,
{ signalwireSpaceUrl: space_url });
Here we get the list of messages sent after 2022/01/01, and if there is a match with the error code we select, we add that particular message information to the data
array.
let data = [];
client.messages.list({
dateSentAfter: new Date(Date.UTC(2022, 01, 01))
.then((messages) => {
messages.forEach((message) => {
if (message.errorCode == 11200) {
data.push([
message.from,
message.to,
message.dateSent,
message.sid,
message.errorCode
Here we create a DataFrame from the data
array, set our desired table formatting configuration, and then print all of it to the terminal. Lastly, we export it to CSV for future reference or to simplify the process of gathering relevant informatio to our Support team.
.then(() => {
let allData = new dfd.DataFrame(data, {
columns: [
"From",
"To",
"Date",
"Message SID",
"Error Code",
config: {
tableDisplayConfig: {
columns: [
{ width: 1 },
{ width: 13 },
{ width: 13 },
{ width: 24 },
{ width: 36 },
{ width: 13 }
allData.print();
fs.writeFileSync("Messages.csv", dfd.toCSV(allData));
PHP
How to Run Snippet?
If you save this code snippet in a file called listMessagesWithSpecificError.php
php listMessagesWithSpecificError.php
Code Walkthrough
<?php
require __DIR__ .'/vendor/autoload.php';
use SignalWire\Rest\Client;
, project_id
, and access_token
$client = new Client('YOUR-PROJECT-ID', 'PTYOUR-API-TOKEN', array("signalwireSpaceUrl" => "YOURSPACEURL.signalwire.com"));
Here we get the list of messages sent after 2022/01/01, but before 2022/04/29. If you only want to look for messages sent after a date, but not before a specific date you could comment out that line.
// Can filter message by whatever parameters you need. This example is any message sent after January 1, 2022.
"dateSentAfter" => "2022-01-01",
"dateSentBefore" => "2022-04-29",
Create the error array and the output CSV
We setup an array $header_fields
to help organize our output CSV. We then open our output CSV Messages.csv
and print the header row to it. Here we also create an array $errors
and set our desired error codes to filter on.
// Write Headers for output CSV.
$header_fields = array('From', 'To', 'Date Sent', 'Message SID', 'Error Code');
echo '"'.implode('","', $header_fields).'"'."\n";
// Open File named Messages.csv
$fp = fopen('Messages.csv', 'w');
// Insert headers into output Messages.csv file.
fputcsv($fp, $header_fields);
// Define array of valid error codes you want to look for
$errors = array(
'11200',
'32000',
Write out the relevant messages to CSV
For this last step we'll set up an array $row
of output data from the messages matching the specified fields from our earlier headers, and then also filter to exclude results that do not have the relevant error codes. We then print this data to our output CSV and then close that file.
// Write rows
$row = array(
$message->from,
$message->to,
$message->sid,
$message->errorCode
// Exclude any records where there is no error code present.
if (!in_array($row[4],$errors)) {
continue;
// Insert rows into CSV
fputcsv($fp, $row);
// close file
fclose($fp);
Wrap up
In case something ever goes wrong with your messaging traffic, using this snippet you now know how to get relevant message information to investigate the problem or ask our Support team for help!
Updated 4 days ago
