Retrying Failed Faxes - Node.js
Example application that sends Faxes, and retries if it fails
This is a simple guide using the SignalWire NodeJS SDK and Express to create an application that can send faxes, detected failed faxes with status callbacks, and perform one retry.
View the full code on our Github here.
You will also need the SignalWire NodeJS SDK here
You will also need to install the NodeJS Express Web Framework here
For demonstration and testing you may also need ngrok here
How to run this application
Run natively
By default you can run node app.js
in your terminal and express and ngrok will run on port 3000.
Once ngrok spins up it should log the ngrok tunnel url to your console.
To send a test fax navigate to the ngrokurl/quicksend
. This will return a fax SID that you can check in your Signalwire Dashboard.
Code Walkthrough
The code walkthrough is truncated to only include the most relevant functions. The full code can be found on our Github here.
This repository will inclue the app.js
and accompanying package.json
and package-lock.json
files.
Additionally, this repository will include an example.env
file that you can copy and save with your own credentials as .env
Environment File Setup
Save this file as .env
after populating it withy our own data
# This is the full name of your SignalWire Space. e.g.: example.signalwire.com
SIGNALWIRE_SPACE_URL=
SIGNALWIRE_PROJECT_ID=
SIGNALWIRE_API_TOKEN=
# The phone number you'll be using for this Snippet. Must include the `+1` ex. `+11231231234`
SIGNALWIRE_FROMNUMBER=+1<10dlc number>
SIGNALWIRE_TONUMBER=+1<10dlc number>
# If you have an Ngrok account you can include your auth token here.
NGROKTOKEN=
#If hosting this app, enter the host domain here and remove the ngrok tunnel
DOMAIN =
App.JS set up
First we will need to require our Express, Ngrok, and Rest Client packages. Here we will also assign our Environment Variables.
const ngrok = require('ngrok');
const { RestClient } = require('@signalwire/node')
let DOMAIN = ""
const FROM_NUMBER = process.env.SIGNALWIRE_FROMNUMBER;
const TO_NUMBER = process.env.SIGNALWIRE_TONUMBER;
const SIGNALWIRE_PROJECT = process.env.SIGNALWIRE_PROJECT_ID;
const SIGNALWIRE_TOKEN = process.env.SIGNALWIRE_API_TOKEN;
const SIGNALWIRE_SPACE = process.env.SIGNALWIRE_SPACE_URL;
SendFax Function
This function will be what sends our faxes. It will accept a number
that will be the number we send the fax, and a querystring
Next the function creates our Rest Client, sends a new fax, and sets the statuscallback
using our formaturl
function.
Finally we will log the fax.sid to our console, and return it to the client.
async function sendFaxTo(number, querystring = '') {
const client = new RestClient(SIGNALWIRE_PROJECT, SIGNALWIRE_TOKEN, { signalwireSpaceUrl: SIGNALWIRE_SPACE})
const fax = await client.fax.faxes.create({
to: number,
mediaUrl: 'https://www.w3.org/WAI/ER/tests/xhtml/testfiles/resources/pdf/dummy.pdf',
statusCallback: formatUrl('callback', querystring)
console.log('Done', fax.sid)
return fax.sid
App Route: QuickSend
This route is a very swift way of creating a test fax. It will call our sendFaxTo()
function and pass our TO_NUMBER
environment variable.
app.get("/quicksend", async (req, res, next) => {
sid = await sendFaxTo(TO_NUMBER)
res.send(sid);
App Route: Callback
This route handles our status callbacks. If a fax fails we will re-call our sendFaxTo this time passing a querystring. Any faxes that have already been retried once will not be retried again.
app.post("/callback", async (req, res, next) => {
console.log(req.body);
if (req.body.FaxStatus == 'failed') {
// retry if we haven't retried already
if (req.query.retry) {
console.log('no retry');
} else {
console.log('retrying');
await sendFaxTo(req.body.To, '?retry=1')
Ngrok Function
This function starts our ngrok tunnel on port 3000, logs the url to our console, and sets our DOMAIN to the url. Comment/delete this out and set DOMAIN to your app's host DOMAIN in production.
(async function() {
const url = await ngrok.connect(3000);
console.log(url)
DOMAIN = url
Formaturl function
This function is how we will append actions and querystrings to our domain URLS. This is primarily used when creating a statuscallback url for our sendFaxTo()
method
function formatUrl(action, querystring = '') {
return DOMAIN + "/" + action + querystring;
App.Listen
Points our app to port 3000, this port should match the port that we launch ngrok to.
app.listen(process.env.PORT || 3000, () => {
Wrap Up
This guide is a great way to get an understanding of how SignalWire's API can be used to send out faxes and properly make use of statuscallbacks to detect and retry failed faxes.
Updated 23 days ago
