Build a Simple IVR with Dotnet Core C#
This is a very simple example of how to gather input from a user and act accordingly.
It is based on the Dotnet Web API quickstart.
To run it, use dotnet restore followed by dotnet run and head to http://localhost:3232/api/voice
You may need to use a SSH tunnel for testing this code if running on your local machine. – we recommend ngrok. You can learn more about how to use ngrok here.
What’s Next
Check out the full code on our SignalWire Github Repo!
