Retrieve Appointment Information - Python
This guide will give a basic demonstration of how SignalWire's Communication API can be used to create a simple relay that will use speech and dtmf input to retrieve a user's data, provide that data over text-to-speech, and follow up with an offer to text the data over SMS.
Check out the full code on our GitHub here
The only things you will need to run this code are SignalWire's Python SDK and your SignalWire Credentials. You can find these by logging into your SignalWire space and navigating to the API tab. For more information on navigating your SignalWire space check here
How to Run the Application
Build and Run natively
Run app.py in your python environment of choice
Step by Step code walkthrough
This application runs in one app.py
file.
You will need to create a copy of example.env
and fill it in with your own values.
Code Breakdown
Getting Started:
First, we will import our Consumer
from the SignalWire Relay API. We will also import os
and load_dotenv
from dotenv
which will handle our environment variables containing our SignalWire credentials. Next, we will establish our CustomConsumer class and create a function within that class called setup. This function will contain our environment variables, as well as our relay context, and some additional variables.
self.clientlist
is a python dictionary where each key is assigned to a list of data.
self.nameslist
is a python list that will gather our keys to pass to the speech_hints
parameter later on
self.mapper
will assist us in catching bad inputs and self.menuloop
handles our while
loop.
from signalwire.relay.consumer import Consumer
import os
class CustomConsumer(Consumer):
def setup(self):
# holds our environment variables
self.project = os.environ['ProjectID']
self.token = os.environ['AuthToken']
self.url = os.environ['SpaceUrl']
# make sure your signalwire number is pointed to this context
self.contexts = ['office']
# this is our simulated data to retrieve
self.clientlist = {"example man": ["December 15th at 2pm", "1995"], "example woman":["December 20th at 2pm","1999"]}
# this nameslist will be used to create speech hints to improve our detection
self.nameslist = []
# helps handle bad input
self.mapper = "default"
# controls our menu loop
self.menuloop = "0"
Handling Incoming Calls
Within the consumer class, we will create a function called on_incoming_call
and pass the self
and call
arguments. When a phone number points to the office
context we set in the previous step, the consumer will pass the call to this function. From here we will answer the call, and if we answer successfully we will begin the main loop of our application. When this loop starts it will reset our menuloop
, clientid
, and mapper
variables, just to be safe. Finally, this is the point where we will poll our clientlist
dictionary and append the keys to our nameslist
async def on_incoming_call(self, call):
result = await call.answer()
# starts our IVR only if the call is successful
if result.successful:
# resets menu loop and client id with each call
self.menuloop = "0"
clientid = ""
while self.menuloop == "0":
# resets our bad input catcher at beginning of the loop
# creates a list of names to be used as speech hints
for k in self.clientlist:
self.nameslist.append(k)
Getting a Client ID
Now that we have our nameslist
populated, we can prompt the user with text-to-speech and ask them for their first and last name. If we receive input from the caller, but it is not recognized in the clientlist
, we will set our mapper
to unrecognized which will play some more tts and allow the caller to try again.
If the input was found, we will loop through the clientlist
and set our clientid
to the key. After that, we will call our pinprompt
function and pass the call
and clientid
variables.
If for whatever reason our input is not successful, our mapper
will default to play some tts and start from the beginning, additionally a check is made to ensure that dropped calls do not hang the consumer and make it unavailable for further use.
# first contact, prompt user for their name
result = await call.prompt_tts(prompt_type="speech",
text="Please say your first and last name.",
end_silence_timeout="2",
speech_hints=self.nameslist)
# if our result is successful, but not recognized as a client
if result.successful and result.result not in self.clientlist:
self.mapper = "unrecognized name"
# if our result was successful and found in client list
if result.successful and self.mapper != "unrecognized name":
# loop through client list and set clientid to the matching key
if result.successful and result.result == k:
clientid = k
#send call and clientid to the pinprompt function
await self.pinprompt(call,clientid)
# catches bad inputs - this is what will happen by default
if self.mapper == "default":
await call.play_tts(
text="Sorry. I am still a new AI, and didn't understand your request. Try again.")
# if a client's name could not be found
if self.mapper == "unrecognized name":
text="Sorry, I could not find your name in our record. Please try again.")
# ends the while loop when a call ends or is dropped
if call.state != "answered":
self.menuloop = "1"
Using Pinprompt
This function is called when a caller is successfully found in our clientlist
dictionary. First, we will ask them for a pin, which in this example is their birth year. If the pin is incorrect, we will inform the user and kick them back to the main menu.
If the pin is correct, we will provide the caller with the requested information over text-to-speech, and finally send them to the smsoffering
function once again passing the call
and clientid
variables.
async def pinprompt(self,call,clientid):
# prompts user for their pin
result = await call.prompt_tts(prompt_type="digits",
text=clientid + "Please enter the year you were born.",
digits_max="4")
# if the pin is incorrect we are kicked back to the main menu
if result.successful and result.result != self.clientlist[clientid][1]:
await call.play_tts(text="That was not correct. Please try again.")
# if the pin is correct we will tts their appointment details
if result.successful and result.result == self.clientlist[clientid][1]:
await call.play_tts(text=clientid + " your appointment is on " + self.clientlist[clientid][0])
# next we will call our smsoffering function
await self.smsoffering(call,clientid)
Offering data over SMS
Now we will simply ask the user if they would like to receive a text with the information we have retrieved for them.
If the user says yes, we will use the information from our call
to create a message with the appropriate information and end the call. If the user says no, or the user's input could not be parsed, we will just say goodbye and hang up.
The final two lines instruct the consumer to run when we run the script.
async def smsoffering(self,call,clientid):
# ask the user if they would like to receive a message with their appointment details
text="Would you like to recieve a text with this information?",
end_silence_timeout="1",
speech_hints=("yes", "no")
# if yes, send details to caller with sms and hang up
if result.successful and result.result == "yes":
txtresult = await self.client.messaging.send(context='office', from_number=call.to_number,
to_number=call.from_number,
body=clientid + " your appointment is on " +
await call.play_tts(text="Your details will be messaged to you shortly. Goodbye.")
await call.hangup()
# otherwise just hang up
if not result.successful or result.result != "yes":
await call.play_tts(text="Goodbye.")
await call.hangup()
# Runs the consumer
consumer = CustomConsumer()
consumer.run()
Wrap Up.
This guide dives into a variety of tools that SignalWire's communication API provides to create a powerful data retrieval application in barely over 100 lines of code(including comments!).
Required Resources:
Github Repo
Python SignalWire SDK
Updated 22 days ago
